My dbrand leather skin is in transit, should hopefully have it by the end of the week.
I haven't had any issues with the fingerprint reader on the S7 Edge, it's probably even slightly better than my S6 Edge was, but that might be because I took some of the tips and registered both thumb and index fingers on both hands.
It won't trip KnoxHas anyone gone and stuck the stock UK Firmware on their phone yet? Would that affect Knox on the phone?
Tempted to do mine as can't be asked waiting for slow updates from Vodafone.
It won't trip Knox
My S7 is sim free though I did flash the BTU ROM on my colleagues O2 UK Branded S6 and its been working spot on.
No problem, you shouldn't need to wipe any data as its the same OS but I generally prefer to do a wipe after flashing a ROM on it.Thanks for that, going to give it a go later.
^^What are you using for testing?
