Nope, one or the other. Same with the plastic protectors n all.
Why is that? Don't see a reason that you can't have both?
Does anybody know of a tempered glass screen that will fit with a Spigen Tough Armor case?
Every case has an overlapped lip top and bottom for grip and most of them don't have clearance at the sides either.
Anyone taken low light shots in the Pro mode? Wondering if the camera is as good as the Note5![]()
Is this specifically for the S7/e?
I have applied a glass screen protector and a normal gel case to many phones without issue.
Examples of the S6
http://forum.xda-developers.com/showpost.php?p=62794241&postcount=49
http://forum.xda-developers.com/showpost.php?p=60172892&postcount=75
http://forum.xda-developers.com/showpost.php?p=65547401&postcount=137
Been testing a few SD cards in mine
Samsung evo 64gb
read 40.42mb/s
write 20.52mb/s
Still tempted by this but the only thing holding me back is how slow Samsung are with Android updates![]()
Sorry, the edge i'm on about.
Any one else feel the same?
My black S7 Edge arrives from Very.co.uk today. Just ordered a Spigen thin fit case for it.
I wish I had jumped on that 128GB MicroSD card at Amazon for £29.99 4 days ago
EDIT: This looks like a reasonable alternative.
As can be seen below - screen protector still allows a case to be put on...no issues
