You should go for the edge version so you get the 3600 mAh battery...Annoyingly there is currently only £15 difference between white edge and white flat grrr
Has anyone gone and stuck the stock UK Firmware on their phone yet? Would that affect Knox on the phone?
Tempted to do mine as can't be asked waiting for slow updates from Vodafone.
Been testing a few SD cards in mine
Samsung evo 64gb
read 40.42mb/s
write 20.52mb/s
Samsung evo plus 64gb
read 69.42mb/s
write 24.10mb/s
Got the S7 flat and enjoying the device but have noticed the fingerprint reader has roughly a 50% failure rate. I've added both thumbs twice, I'll try adding the same finger four times to see if it improves.
I know most people are happy with the fingerprint reader but its been pretty bad for me, when it works its great but finding it very hit and miss, I even have my thumb registered four times and doesn't always work.
I do get slightly dry skin so wonder if that is making any difference, maybe a few tiny bits of rough skin at times mess with it?
Think I'm going to delete all four and start again.
I have skin like a rhino and my fingerprint scanner works pretty well. The heart rate monitor not so much.
Why is everyone so desperate for this update? Its nothing major is it, just confused that everyone seems to want it straight away.
Does anybody know of a tempered glass screen that will fit with a Spigen Tough Armor case?
Nope, one or the other. Same with the plastic protectors n all.
