I have the Strafe and the scimitar...love them...amazing gear.. firmware is bugged out but most of the issues are fixed now.
. As I understand if you pm one of the corsair guys on corsairs forums they will give you a beta CUE that fixes the issues people are experiencing atm, specially with the scimitar.Yeah, that was an after market key caps. There's a few places online that you can get those transparent ones.
Saw some over here, just not sure if they have clear ones. https://www.overclockers.co.uk/search/index/sSearch/key+caps/sPerPage/12/sPage/1
Once the power has been switched off at the wall, upon start up my Corsair K65 cycles through random colours/patterns and decides not to recognise any key's being pressed until I unplug and plug back in it then recognises my saved profile and begins and allows me to type... Anyone have this problem?
If the power is never switched off I don't have this problem.
