All e liquids now make me cough, glad I didn't invest much, gp thinks it's the pg irritating my throat![]()
Just ordered the following from FT:
28/32 316L Clapton spool
26/32 316L Clapton spool
22/32 316L Clapton spool
Alien wire fecral spool
All 5m spools, £14 delivered
On a supreme note, agree with everything rilot wrote a few posts back, can't put this thing down.
That's cheap! Do you have any experience with fecral wire, what's it like?
I've got some crazy wire Clapton wire that rusts after one/two tanks, will definitely not be using it anymore. It's kanthal wrapped in NC, never had he problem before and will probably get UD wire from now on.
I didn't realise this but on the RX200 (presume other joyetech/wismec mods) turn the device off, hold power and menu down and it tells you the voltage of each cell![]()
I (and I believe rilot) got direct from steam crave in Asia, though essex vapours have UK based stock at a similar price you'll pay direct from SC: https://essex-vapours.co.uk/products/aromamizer-supreme-rdta-by-steamcrave?variant=11274370245
Thinking of grabbing another and another RX200 and getting rid of just about everything else.
To me it rights every wrong every other rta I've tried has. It doesn't leak, easy to fill, big capacity, easy to build on, wicking is simple, you'd have to go nuts with watts and choke the juice control to get a dry hit, airflow is superb, the list gos on![]()
