I doubt temp is 50c at full load unless you live in Antarctic.
Mines is watercooled so 50c is about right think max I've every seen is 52c
At the moment 1500/4000 on EVGA 980 Ti SC+What sort of overclock? And what's your ambient?
Can only get my 980ti to +100 GPU and +300 mem. After that its locks up
According to Zoson:
GPC = "General Purpose Core" - This is the primary core of your GPU
L2C = "L2 Cache" - This is the on core memory that your GPU core has access to. Running it at the same clockspeed as the core itself nets a large gain.
XBAR = "Memory Controler Crossbar" - This is the bus speed of the memory controller that talks to the core.
SYS = "System" - This is the rest of the card that isn't tied to another clock domain.
So it looks like these are internal clocks for various parts like memory bus and L2 cache speeds.
And if MSI AB adds offsets so it is another proof that these clocks should be of a precise difference to general gpu clock.
Your right on your list but think of it this way.
If you don't use AB or other OC app, the max boost = from boost table (clock74)=P00 GPC max value .
With lower values those parts will clock lower. If you make them all the same as GPC then all sections of GPU run the same, that was how Kepler was, but of course Kepler wasn't clocked so high.
Cheers digitalx.
Think I may just purchase 1 hybrid to start and check the mounting points. I have a corsair h100 so fitting the rad to the roof is not an option.
If I do use two, then one of the rads will have to fit at the back with the other connected either to the bottom or front.
One 980ti is about equal to 780 sli, (made this switch myself). Psu would be ok too as long as you arent overvolting the cards when pushing for overclocks.Am I correct in assuming that one 980ti is equivalent to two 780's, not ti's? Mine do not clock well and max at c 1050 core clock.
Finally, would my EVGA 1000w power supply be enough for the cards?
Cheers
edit: my motherboard is no longer the gene.
Cheers Setter.
I'm going to order one hybrid for Saturday delivery. If all is well with the bottom or front mount, then will order a second.
Some 980Ti Classified overclocking memory / core results in Heaven 4.
Heaven 4 1080p, 8xAA, Extreme Tess
96.5 fps - 1405mhz. 3506 mem
100 fps - 1500mhz. 3506 mem
101.3 fps - 1405mhz. 4001 mem
106 fps - 1500mhz. 4001 mem
slowly getting there?![]()
