- 21 Apr 2006
I took the 701 for its first proper run out. Whilst I get used to the bike I set the engine map to "soft". It supposedly smooths out the low end torque...
Even on "soft" that bike pulls - with a bit of throttle I had to literally cling on tightly, leaning forward onto the bike, I was almost fearful to release my left hand to clutch in. It's crazy, and insane fun. Will have to be careful to keep things legal
I overtook a car which pulled into my lane suddenly at one point, and throttling it a bit too sudden brought the front wheel up - I was in 4th(!) ahah.
The bike itself is amazing. The balance is perfect, just move slightly and the bike moves - it seems like it leans in on its own. The suspension is amazing too. It's very easy to ride.
The one negative to the ride was cracking the speedometer screen
. It suddenly started blowing a gale and hailing, and some hail cracked it. I'll have to call the dealers to see if the glass can be replaced.
I can't wait to find out what the standard and advanced maps are like
.I overtook a car which pulled into my lane suddenly at one point, and throttling it a bit too sudden brought the front wheel up - I was in 4th(!) ahah.
. It suddenly started blowing a gale and hailing, and some hail cracked it. I'll have to call the dealers to see if the glass can be replaced.I can't wait to find out what the standard and advanced maps are like
Even 120kph bang on is 8000rpm. A few hours of that is OK, but it gets annoying after a while.
