I won't be getting a 980ti but will wait for pascal, which if rumor be believed should support the freesync. Failing that the other half will get a lovely hand me down
I really cannot justify the premium for the X34 at this time, I could upgrade a few other bits for that difference.
Where did you hear that the pascal will support freesync?
That is 3 TV shows now where 21.9 monitors have been shown of a bit, legends of tomorrow, heroes reborn (the bad woman has one as her office monitor) and arrow (Felicity has about 3 separate setups each with 3 dell 34" monitors)They never will. They might... with a small % chance.. support Adaptive Sync.. Big difference.
i cant see nvidia supporting freesync any time soon but i would not be surprised to see a hack for freesync in the near future
Apologies, I did mean AdaptiveSync, which I was mistakingly thinking it would be that same as Freesync.
21.9 is so now![]()
I'm not sure why Nvidia would support adaptive sync. The gsync solution is clearly better, it just works, and has a better range.
No.They are both equally as effective at eliminating tearing, juddering and stuttering from the traditional refresh rate and frame rate mismatches. I've seen some fairly good pixel overdrive implementations for both FreeSync and G-SYNC models and also some not so good ones. And if there are any latency differences they're certainly beyond my sensitivity for that sort of thing.
Low frame rates are low frame rates regardless. You really don't want to be getting under 56fps or anywhere near that on a 144Hz monitor, it feels and looks extremely sluggish. And besides, now that AMD has LFC the frame rates below the hardware floor (56Hz/56fps) are suitably compensated for to remove stuttering and tearing. It's very much a non-issue really.
