The best program for real life load; Realbench v2.43. I have very good case cooling.Wow, what are you using to put it under load? I have the same cooler but my load temps are closer to 85.
As 3.6ghz was the max I could get I'm hoping for some reasonable gains in performance and features such as sata3 and m.2.3.6GHz it is quite low to be honest, by going with a 6600k with some nice OC at 4.5GHz you can expect the single thread performance to increase around 80%.Noticed the other day that league of legends was near on maxing out a single thread leaving the other 11 idle. Have decided to just go ahead with a new 6600k setup as I got a good deal. Since getting the Xeon I've only used the extra cores for benching so the improved IPC should help in games.
Going to run some benchies at the weekend.As 3.6ghz was the max I could get I'm hoping for some reasonable gains in performance and features such as sata3 and m.2.
@AiiR Depends on the game really if it is gpu bound you will not see any difference even if the 6600k had infinite power, however on the games that are cpu bound the difference will be grate. I move from [email protected] to [email protected] and I see my fps to increase 60-70% on games that are single thread bounded.
Could someone do me a favour and use the bench tab on CPU-z and let me know what single and multi scores you get for 4GHz and 4.4GHz
Thanks!![]()
Anyone here upgraded to a 5820k from a 5650 @4.4 that's what I have and thinking about it gaming only thanks had a quick look Thru but there so many pages ha
Guys. I'm running my x5670 at 4.2ghz, and i'm sure it can go higher, but..
I'm using Thermalright 120 Ultra now, with 1 fan only (noctua one).
Temperatures are ok, but during stress around 70-80. I'm worried that summertime temp might go up...
Just thinking invest in Watercooling kit (EK or XSPC) which are around 250-300 quid (don't see point of buying AIO).
So the question is, where to invest? sell X58 system and put 300 towards newer system, or get WC and stay with X58.
BTW what rough price i can look for if i sell
Gigabyte G1 x58 Guerrilla, 24Gb Kingston Genesis 1600mhz and x5670 obv with Thermalright.
Get an aio
This.
