Many find 16:9 far better for gaming then superwide. Been trying to find a good replacement monitor for my 6 year old one but there just isn't anything worth while to upgrade from (Dell U2711). I don't like curved screens as they are rubbish due to distorting the image and ruin the game look. Superwide has less height to the screen then 16:9 and often has UI problems. Personally I find the X34 predator a rubbish gaming monitor. I would rather have my 6 year old screen then that thing and it wouldn't surprise me to find out curved screens are a fad that fades away over the years. There are no real advantage to curved screens, only disadvantage like worse viewing angles to distortion. EDIT: Superwide I can see a use for in work its just I don't like the loss in screen height. Superwide have a lot less height to them.
Don't knock curved until you have seen a 34" 21.9 monitor. IMO, it is a very nice addition as the 34" screens are so wide that the curved helps with the viewing experience i.e. you can see the corners better + it feels even more immersive, not to mention it also helps reduce the IPS glow in the corners, which is much needed for those 34" screens.
If you are doing photoshop, CAD or whatever type of work then yes a curved screen won't be a good screen to use but for any media consumption, it is great. Although, only a subtle curve, not a steep curve like the upcoming Samsung monitors.
Curved for everything else is absolutely pointless though especially TVs.
Also, you don't "lose" height with 21.9 screens, they also don't "gain" height to their 16.9 equivalents, that is down to how the aspect ratio works.
Most games all work very well with 21.9 too, I don't think I have got one game on my system where I can't get 21.9 to work, be it supported officially or a simple tweak in a config file to enable it. Most games have UI/HUD problems though i.e. they will be stuck in 16.9 position, which is rather annoying but not a deal breaker.
Everything else you need to know about 21.9 can be found here:
https://forums.overclockers.co.uk/showthread.php?t=18684417
EDIT:
Also worth noting that 21.9 resolutions have over taken 4k on steam survey now, considering how long 4k has been out as well as the huge variety to choose from, not bad going at all for 21.9
