You getting one mate ?
Nope, current card will do until 1080ti. Other avenues for cash theese days.
Yep, as there isn't going to be a Ti, the 1080s the high end card![]()
Not you hunny, you are a shining light brighter than Polaris![]()
Just under 10.5 inches.![]()
this
Exactly...
So would not surprise me seeing them partners coming in at £699 +
i know its an exaggeration but from what i am seeing and hearing its looking to be the case....however peeps will still justify buying them ...this is crazy just crazy..
Paying the kind of money they want for the "Founders Edition" (initial production with high defectivity) is absolute madness. NVIDIA reference designs are hugely cost cut.
It's using really crappy 6 phase power regulation 5, plus 1 for memory, for a card that boosts upwards of 1.7Ghz and which according to initial tests can draw as much as 300W under some loads (vastly exceeding its stated TDP). These cards are going to die or degrade so damned quickly.
Non-reference will be cheaper and much better, and weeks (or months) later from less defective non-initial production. Also, AMD cards will all be on the market by then (except Vega), so prices won't be as high anyway.
You're getting a crap card at a huge mark-up if you buy a Founders Edition.
But the FE is built to a higher spec with trusted components and a premium cooler!!!! That's what the nvidia man says so it must be worth the premium!!!![]()
I am not sure 300 watt can be pulled down one rail 6 pin .....but i am no expert power gpu atx engineer ....
Good job I have exams to occupy myself hahaBut the man from nvidia he said it's worth the extra money! He wouldn't lie
Intel and Nvidia and Apple are all drinking the same Kool-Aid.. They are taking the micky selling what really is a mid range part in their selection at what was high end parts prices only a couple of years ago at max.
It's similar to the gaming preorder fiasco. People keep throwing money at devs before they've even finished the game and wonder why they turn up s***
I remember buying stuff many many years ago and getting over two dollars to the pound, how I wish those times would return.
