Beat me to it
Valve clearance time! luckily it was only the exhaust side that needed adjusting.
When changing valve shims its much easier to work on one cam shaft at a time.
Working on 1 cam shaft at a time means you can use cable ties to hold the chain to both sprocket which means you dont have to worry about losing the timing.
With the chain tied to the sprocket and the cam chain tensioner removed there is just enough room to lift the cam shaft out of position and clear of the buckets.
with the cam shaft out of the way its a good idea to stuff rag in any holes that the shim may fall into.
Its easy to remove the bucket with a magnet, some times the shim will stay on the valve.
other times it will stick to the inside of the bucket.
Once the bucket is out it's just a case of inserting the correct size shim and putting every thing back together the way it came out remembering to tighten the journal caps in a criss-cross pattern.
Impressive. I wish I had the ability to do my valve clearances myself. It'd save me £600![]()
That's a pretty strong reason to learn right there, £600 is a lot of petrol/shiny bits/post ride beers.
I can guarantee I'd mess something up. I always do, but on things that are inexpensive to replace.
I have always found when fixing something on a 2nd hand bike I sometimes find things that other people have broken and end up fixing that which then reveals something else etcSo I'm not the only one that constantly breaks something whilst trying to fix something else?![]()
Went to get some beers after (my excuse) and had the typical 'how much, how fast?' from some chav, then proceeded to go into the shop and keep a keen eye on my bike.
You still have your safety stickers?!
Cheers, Sportsbikeshop sent me a blue one by accident first, was not happy but they sorted it ASAP.Looks great flack,matches the paint perfect
Yeah its only on around 6500 miles. Never thought to take them off lol.
I was going to leave mine on until I broke it in as it had all the rev ranges. Ended up taking them off on day 2![]()
Yeah I remember they sent you the wrong colour, hope they gave you a discount
I'd leave the stickers on myself,still have mine on,upto you though
