Well game was preloaded yesterday, booted up steam about 20 mins ago and it seems to be updating/unpacking again. Unlock time?
I had to shut down Afterburner to get this to work. Black screen otherwise. It's an old version of AB so maybe that is the issue.
Are you supposed to be able to pick Chaos from the off, if you've got the pre-order? I'm not sure under what conditions you can use them as on the main screen under DLC, I've got Chaos there but campaign seems to only be the other four races.
£28 from cdkeys with warhammer666 code - pre-loaded and ready for launch![]()
Mine doesnt go anywhere further than the Warhammer splash screen when you load it up. Disabled AB....no change.
Some user feedback seems to state otherwise... https://forums.totalwar.com/discussion/174041/system-performance-as-of-now#latest
maybe different hardware configs are causing issues... but still if the CPU usage is so bad then CA really need to sort that out because in 2016 its just ridiculous.
It is still bad, always has been bad and probably always will ( maybe the dx12 patch will improve it though)
Still get slow downs with lots of units on screen on ultra detail even on a 4.4ghz 5280k. People claiming they get 60fps locked on these games using ultra details are just outright lying. I have been through multiple configurations ( different chipsets, cpus, graphics cards etc) and these games are always the same. Loads of units fighting on screen = slow downs.
Well at some point all 8 cores were at 90%, doesn't mean they were all at 90% at the same time. Need to be seeing the real time usage in game.
Reading this makes me cringe for my Lil ol' laptop
