- 24 Mar 2011
- Kent
Yep, it'll have 79(tri) or similar against it, just means she has a provisional bike licence. the 79(tri) means limited to trikes (which you can ride/drive on a car licence).
You don't need to take another test do you? I thought after 2 years on A2 you automatically jump to an unrestricted license?
Wow, really? The EU really doesn't want bikers any longer!
I concur, it just frustrates me they don't take power/weight ratio into factor as one of my younger friends (21) rides an ER6F which is constantly speeding pass me, is also restricted to 47hp (it's not that I want speed it's just the principal.)
When I take exactly the same test that I've already done again and pass on either my bike or a schools 600cc it means on paper I'm qualified to ride a Ducati 1199, I won't be gaining any more experience from doing so, just the ability to be able to.
They do take power to weight ratio into consideration but only as an upper limit, it was your choice to run a big old tractor restricted![]()
Haha right there pal, however I'm removing the restriction real soon.
It just baffles me;
I need to take the same test I've already done before,
only this time on a bike I've ridden for almost two years,
to prove I can ride a larger bike,
which will be my bike,
qualified to ride cbr1000rr.
It just baffles me;
A lot of schools will offer PAYG lessons then you pay for the tests/bike hire when needed, it'll probably be a bit more expensive in the end but means you can spread the cost.
