Permabanned
- 23 Apr 2014
- Hertfordshire
I need a reasonably priced battery/box thing that has temperature control, dont really want to spend much more than £50. Any suggestions?
Why don't they work with the Kbox mini? They are just normal Kanthal coils. Well, they could be titanium, ni200, kanthal or SS actually depending on what version you bought. The SS part of SSOCC doesn't mean that they are SS coils, just that the coil casing is made from SS. Kind of misleading TBH.
Even if they were SS coils they will work with your Kbox just only on power mode.
Evening fellas, back again for some help.
Bought a Joytech mini after some recommendations on here and then popped into a new vape shop that opened near my office. They didn't sell the brand of juice I usually get, van Dyke vapes, so he recommended I try this other one called element, pink grapefruit flavour.
I gave it a go and was pretty happy with it, very smooth and whatnot.
Anyway I was chugging away on that but then towards the end of the bottle I started to notice it got proper harsh on my throat, like how it gets when it's a dry pull or the setting is just way too high.
I assumed it was just because there wasn't much juice in the thing so I went back to the shop, told the guy and he tried it, asked how old the coil was and when I told him it was like a month he said change it.
I bought some more juice and another coil, went home and changed it, filled it back up and it's possibly even harsher than before now. Then I checked the strength and saw I had 6mg and before I had 3mg, I'd bought both though this time so I emptied it out, filled it back up with 3 and guess what, it's still harsher than a holocaust joke.
The guy said the wattage should be around 15 but there it's really harsh and quite cloudy so I reduced it down to about 7w and it's hardly pulling anything but what it is, is super harsh.
Anyone any ideas? I'm getting really frustrated with it now, I had my mvp 2.0 and nautilus mini for over a year without anywhere near this much hassle, I'd go back to it if it wasn't a nightmare to refill every time.
iirc element liquids are coil killers, high in sweeteners, check your coil it may need replaced even if it is quite new.
with heavy VG juices like elements you need to prime and allow the the coils to soak for a bit. If it's a new coil and it wasn't prime/soaked correctly, it either burns out giving you a harsh burnt taste for the rest of the coil or the juice just forms a layer on top of the cotton, causing spliting and harsh hits. Elements is really design for dippers as it's so darn thick but will work with tanks like the cleito where the wick holes are massive.
New coils can take a while to break in before they work correctly.. depending on the coil; the length can vary, it's best to start of low and work it upwards to what you normally vape at.
Hmm, didn't know that. I did just whack it in and start trying to chug it immediately. Do you think I've blown the coil? Should I try it again tomorrow when it's soaked in or change it now but risk another coil? Tempted to go back to my old nautilus and Van dyke juice but I could give it another go.
will make sure I stock up whilst the 30% offer is live.
For power only get a Tesla invader 3, absolutely love mine for power builds, very cheap too! Just make sure to pair it with decent batteries e.g. hg2...
