Edit*
Fopund out what is going on with my MK60 codings.
So I read the MK60 with Expertmode (Expertmodus) and that's fine, it saves the trc file and I can open it and view the values as above.
Making the correct changes for my car, then saving it as the MAN file and then switching NCS to the Fister profile, then changing job type to code and hitting execute job results in NCS saying coding finished. But then when I re-read the MK60 and check the TRC file, the MAN file changes have not been saved to the MK60 as it's still showing the stock M Track changes for CS/CSL. This will explain why I'm finding M Track doesn't last as long as I expected before DSC kicks in since I don't have the CS/CSL steering rack or brakes and as suchk the values need to be changed as per the PDF file instructions.
So does this sound like a profile issue in NCS Expert? I'm on version 4.0.1 and this is my profile list:
Obviously my install of NCS is fine, since I was able to enable M Track, read the modules and do everything else. It's the flashing the MAN file to the MK60 that isn't saving the changes. I reckon I'm not on the right profile and no idea why there is more than one Fister profile showing.
