- 5 Sep 2008
As you can see, the switch distance is very low indeed; that's probably the issue you're having. Try raising it in +50 increments and see what value is best. I reckon you'll be looking at something from 250/300+. I think 900 is the max, though after a while I expect you'd see your fps drop like a stone if you employ that value.![]()
150 is default for vanilla CoP.
Misery is around 350 but I use 300, that still allows me to knock down Monolith bods at the water treatment plant from the far end of the bridge on zaton, with a DMR or KSVK and adjustable sights.
