Good luck![]()
Cheers mate. If anything I can come away with a back injury as a souvenir. Just got remember to lean into it.
Good luck![]()
You have one of those programmable keyboards don't you? and you have a recommendation for DBSS mapped to a keybind, so you can just mash it and boom here it comes!
Deficit Bulgarian splits squats for 3 sets of 10 (each side).
Only then can you tell me you have actually trained legs.![]()
What are these legs that you mention? You meant biceps right?
Well... Went to the gym to up my deadlift and....... Failed
Went in. 210-250 all went up pretty quick. 295 on bar it lifted about 6" just below knee. Dropped. Went for a second attempt that I knew wouldn't go lifted a little less distance. Hated it as going down weights flew again.
The heat and clamminess didn't help sadly.
Will be going for it again on next session and mote emphasis on speed work at 220-230
Just wanted say thanks to reitushin for help. Do feel there has been an improvement and felt a 285 would have gone
Biceps femoris = biceps = arms.
That's science.
Bah, sorry you didn't get 295. The weather definitely isn't helping!
So guys - can you give me some more suggestions for shoulder day?
Currently looks like this
OHP / DB Shoulder Press
Front to Side raises
Face Pulls
Close Grip Lat Pulldown / Negative Chin Ups
is it worth adding High Pulls / Shrugs into this, or anything else I should consider?
Edit: DBSS are NOT a shoulder exercise mrthingyx before you suggest those![]()
At what weight would wearing a belt be beneficial when talking deadlifting? I've limited myself to chalk only and my 1 rep max is around 170kg (working sets of 5 x 160kg).
I know if I was to wear a belt I could probably lift more, but is it "cheating", what I mean is are there actually advantages of wearing a belt other than being able to put more weight on a bar to improve your 1 rep max?
Up to you. Some places used to have disagreements on how much safety belts have or at least preventative measure. Eddie Hall once did a 457.2kg deadlift with no belt.
I wear even for warmups and only tighten for big lifts
I've never found a comfortable way to wear my belt for deadlifts, great for squats and OHP though if you're pushing the boundaries.
Shrugs are one exercise, but they're pretty non-functional: better to use a clean or snatch pull... As you will get bigger traps and a bigger back to boot.
Also consider push presses as these are a great way of overloading your shoulders in a "safe" manner.![]()
I've never used cleans or snatch pulls more than the odd set once in a blue moon and mrthingyx is rather fond of my back the big pervert.
