Deleted member 138126
Ah ok, I use Bria too. Was hoping you'd found an actual Wifi SIP phone that's worth having.
It's tempting to get one just so I can have those stats
Can you use the edge router lite with a vdsl connection? If you can im tempted to swap to one to replace my Netgear D6400
I have oneof the orignal Unifi AP's running at home and have just gone and ordered the UAP-AC-LITE from the rainforest for the princely sum on £73 and it will be with me tomorrow. I think I paid more for the original unit when I got it...crazy.
Am now pondering on just doing a straight swap out between the units ot adding this as a second unit upstairs. The house is a new build (2 years old) so walls are plasterboard mounted on metal frame studs and floors are double skin chipboard, so not really a huge amount in the way for signal attenuation. May try it as a straight swap 1st and see how it goes on.
If all goes well with it then may recommend to my brother in law to swap out the ones in his house.
May also look at getting a RPi controller up and running as Mrs S is at work this weekend so have plenty of time to 'tinker'
Yes, but you need a VDSL modem in place. Either use the Openreach modem (this is what I use), or a Draytek Vigor 130 would work well too.
You configure the ERL in pppoe mode so that tells the modem what the user/pass connection details are.
-Consider the Unifi Gateway (practically same as ERL, with that GUI above!)
I now wish I'd bought Pro''s instead of Lite's
Edit - Seems the USG's are in stock just about everywhere except where I checked initally. Ordered!
lease make sure the USG had internet connectivity (PPoE) before you try and adopt it to your Controller, otherwise it always tend to fail adoptionBecause?
TIPlease make sure the USG had internet connectivity (PPoE) before you try and adopt it to your Controller, otherwise it always tend to fail adoption
I got two pro's in the new house, but debating if I want an outdoor on the external garage to cover the garden etc.
or put another pro in the garage and see if that covers the garden
hmmm....
Very useful, thanks
What VDSL modem are you using?mive recently bought a Vigor 130 as my HG612 was playing up.
