An 8GB download is pushing it! Why didn't you quote the figures for a 50GB download and get a bigger difference?
If we assume that we are all consuming licenced media then the only time you're usually going to need to download a really big file is an OS ISO. Not something you usually do on a daily basis.
These high bandwidth packages do have their place, and to me that's where you have multiple users consuming bandwidth.
FALSE!
8GB file @ 152Mbit = 7mins 30s
8GB file @ 200Mbit = 5mins 30s~
I don't know what dimension you're on, but minutes do not equal seconds!
You won't get a modem now, you will get a superhub, and they do have issues having been dumbed down for easy support and non-technical customers. They do have a modem mode you can set them into and then use a proper router if you want something better.
You might find that youre not able to watch Mamma Mia - Recieving Error Code 319 on your Virgin Media TV Catch Up, On Demand or TV Choice service at the moment.
Looking to switch back to VM again. Should I go with VMNG300 modem getting 100/6 or try superhub again getting 150/10 for same price.
Originally I had 50mb using VMNG300 modem and it was flawless, as soon as I got my free upgrade to speed and using originally released superhub it felt awful. Speeds did increase but jitter/pings seemed worse, and it was horrible playing online games.
Is the new superhub still flaky compared to VMNG300.
I'm taking a stab in the dark here but isn't some random modem you have in a drawer not going to work with a new subscription?
Superhub in modem mode should not double-nat.
