You could just wet the sponge? Or keep a spray of quick detailer with it in the boot.
Duhh.... Cheers man.
Depends how competent you are with chemical nomenclature and whether they use IUPAC names or not. Though that's still a bit ambiguous without knowing molarities. Assuming of course it doesnt state pH neutral somewhere on it
Please tell me scientist man
There was no mockery or sarcasm or any such thing in that post. I merely answered your question.
Have just ordered the autoglym bug remover, so will let you know how I get on when it arrives.
Please and thank you! Thanks for the link Conscript, I'll bear it in mind next time Halfords have a 3 for 2Was hoping for a solution that didnt require a full wash though, hopefully Armageus will find the AG Bug Remover will be as good as the rest of their range!
2 Bucket
Clay mitt
Collinite 845
Sonax BSD
http://i.imgur.com/dW1e7mv.jpg[img][/QUOTE]
Why use a quick detailer so soon after waxing the car? I haven't really noticed any more beading with it after waxing, nor is it that nice to work with. I much prefer the meguiars ultimate quick detailer, much easier to work with and can use it while the car is still slightly wet.
