Chain gets cleaned with WD40 cleaner every few weeks, spray it on let it sit give it a good wipe down with a clean rag.
Then that is strange.
Edit: New chain on the way anyway not going to risk it, yes I know I should replace the sprockets as well but cash isn't gushing and the ones on there are fine. Just got to hope I can hunt down my chain riveter now!
NiceI fitted a luggage rack to my husky today. The 701 has no official way of attaching stuff to the back, but a guy fabricates his own racks. He only produces them in small batches, so I snapped one up recently.
I had to drill the fairings, so was a bit nervous, but it all ended up ok
The guy, perunmoto, makes stuff mainly for enduro / supermoto. Here's a link:
http://www.perunmoto.com/
Washed her.
18 months of ownership - 7,500 miles. 4 track days, 3 trips to Germany and back, 35+ 8 minute laps of the ring. Simply stunning.
For all the people who seem to think Aprilia's are unreliable, all that has gone wrong is a rear ABS sensor which was replaced under warranty free of charge. My BMW S1000RR did the same number of miles and had many, many more problems. The only bike i would think to replace her with is a Ducati 1299s or 1199R, but i would still keep the Ape' for track either way.
I will be spending some money on her over the winter and tarting her up a bit more![]()
Washed her.
Looks slow.... ; P
What you thinking of doing to her over the winter?
Fitted my new chain. Planning on trying lubing it with a bottle of scottoiler oil and a paintbrush see if that's any better. Tried to fit an R&G exhaust hanger but as the fixing point on my exhaust isn't a moveable band there was no chance, I think whoever first fitted a new exhaust didn't cut the original pipe short enough so I'm going to take another 10mm off then it should all line up nicely.
