- 5 Nov 2005
Yep I got the full RED screen on these drivers....
Since I updated to 16.7.3 everytime I restart my PC I get a black screen. PC boots up like normal but I've got to switch my monitor off and back on again to get an image.
Anyone else having this issue?
@Tony Since updating Windows to latest version I have not had the desktop flicker.
is that the 1607 update mate?
So is this as black and white as it looks? And none of my auto updates for months and months have worked?
10/05/2016This is mine from downloading and installing...
Radeon Software Version - 16.7.3
Radeon Settings Version - 2016.0718.1747.30147
Driver Packaging Version - 16.30.2311-160718a-305076C
Provider - Advanced Micro Devices, Inc.
2D Driver Version - 8.1.1.1564
Direct3D® Version - 9.14.10.1209
OpenGL® Version - 6.14.10.13447
OpenCL™ Version - 2.0.6.0
AMD Mantle Version - 9.1.10.136
AMD Mantle API Version - 98309
AMD Audio Driver Version - 10.0.0.3
Vulkan Driver Version - 9.1.0.10.17.0
... check your display adapter in device manager and see what driver version you have there.
18/07/2016
16.300.2311.0
I been using auto update fine apart from this release it wouldn't update, I had to uninstall and the install latest version.
16.7.3 has been fine for me unless the OC on my 480 was wrong
Generally it crashed if the core was wrong and red screened / flickered if the memory was
Giz
I'm actually getting put off buying a RX 480 due to the reports of noisy fans. My R9 380 is extremely quiet and I dont want to regret my purchasing decision. Maybe the GTX 1060 will be better for me despite have a freesync monitor.
