It's actually very straightforward. The tools do the work for you.
[Memory]
DefaultHeapInitialAllocMB=768
ScrapHeapSizeMB=256
Are you using ENBoost? It's recommended even if you're not using an ENB: http://wiki.step-project.com/ENBoost
That's what solved my crashing.
What can it indicate though? Bad load order? Just had the skeleton of a dragon fall from the sky right next to me![]()
Things flying into the air/falling out of it can be caused by high FPS. Skyrim's physics engine doesn't like it when you go over 60fps.
Thanks Goose, I'll give that a try. Is finding the correct load order just a hit and miss?
My game is capped at 60FPS, so can't be that.
