Cheers mate, I suppose 10W will have to do then!it won't quickcharge (15W) off that charger but it should still charge at 10W which isn't bad.
Dashcharge is 20W.
Dashcharge is 20W.
Anyone with a oneplus 3 on vodafone in the uk? If so do you get full 4g signal and speeds ok?
Ordered a OnePlus3 Gold/Sand for my wife about a week ago. Estimated delivery date is 1st September :/ That's a long wait...
Hmm thanks for the heads up. I might start looking at something else then. The wife's phone is pretty much on its last legs and I need something kinda sharpish. It's a shame she thinks my 6P is too large as the OnePlus3 is just a tad smaller otherwise I'd buy one for her.I ordered the Gold one Saturday, graphite one is a 4 week wait. Same delivery date as you too.
So has anyone tried the Oxygen 3.5? currently waiting for it to sideload but surprised there is no news about this anywhere other than their forum
Its a community build so only beta with bugs :
Android Pay is not currently supported
Only English is currently supported in several OnePlus apps
Some performance issues
Some UI issues when using custom themes
System UI tuner is unstable (do not use); using the system UI tuner could cause serious issues that can only be resolved via factory reset
You will need to re-register your fingerprints if you have fingerprint authentication enabled
When I ordered my Gold one, it said it would take 2 weeks to arrive, but was posted next day and was here in about 5 days. So you never know, they may arrive sooner than listed.
Yeah I think it is built in. Tempted to install Nova onto the thing just so I can reduce the icon size but I'll hold back for now.Funnily enough mine arrived today too. Very impressive for the price.
I don't know about the Shelf widget, but reading up about it I think it's part of the OxygenOS and can't be moved. Hopefully someone else will know and tell![]()
The missus won't be back until the weekend now so there isn't much I can do with a sim-less device for now. I'll have a little play tonight and then lob it in the box I guess. At least it gives me time to read up on that TGSP that I'd also ordered.
