The metal valve stems on the ST / RS are a classic example of Ford and their dealers inability to realise who the customer is.
What material do you suggest valve stems are made from instead?![]()
I think he is talking about wheels not engines..
Saw a ruby red the other night, looked awesome in the night with the rear lights lit up. Shame it was the ecoboost and sounded a bit pants. Still left me for dust at the traffic lights though...
What I will say about Ford and the dealer ship, they are very modification friendly.
Keeping fingers crossed.![]()
Don't go all soft on us! You still need to kick ass and take names if it doesn't go exactly perfectly.
Of course, but they know my feelings, I don't need to keep raging, now is there chance to turn things round and so far so good.
Gotta keep a somewhat calm approach, if you keep hammering people down and insulting them, then they just think your an idiot and are only helping you because they have to, not because they want too.
I'd rather the dealership respect me and like me, end of the day they are working on your car and I certainly do not want them hating me.
New guy, he knows what happened, he has the chance to turn things round, looks good on him, good for dealership and gets me out of Ford's hair. End of the day so far he is clearly pushing to get the gaskets so quick.
Simple fact is I can watch them do the install, if its all done correct and still leaks then it is no error of theirs but an error of Ford and they will have to replace the entire oil cooler, gaskets and adapter plate next if seals do not do the trick, which they should.
Gibbo, did you replace the clutch assist spring with a lighter one, or just remove it completely? I hated the feel of the clutch pedal on my test drives so much that it almost put me off the car.
I removed it to begin with which improves it a lot, but does make the pedal heavy. I then fitted the Steeda clutch spring, perfect with that.
The stock car I found very hard to pull of and hard to do smooth gear changes as the clutch has zero feel from factory due to the assist spring they use, really does spoil the drive.
