The idle temps on my 920 @ 4.2 with 1.28v were initially high 20's and settled at low 30s. When they crept up to high 30's I took it as a signal to clean my water loop.
What is your vcore? is it o/c'd?
Yup. That's exactly what I'm doing, running 4x4gb in tri-channel. You're correct in that you have to put the sticks in specific slots.
hey mate [and guys]...so, I got 4x8 sticks [matched G.Skill F3] and can't get the system to boot into windows with full 32?...It just sits at the windows logo screen for many minutes, then the spinning wheel/dots for #minutes [I've always reset her, so I dont know if it ever manages to load windows, way too slow and long to find out]. The system appears fine in the bios with all sticks registered - just windows doesnt load. When I remove the fourth stick [from the special tri-channel denoted slot when using 4 sticks], the 24gb behaves exactly as expected. Did you experience anything like this? UD5's and Extremes are basically the same? Thanks a lot for any thoughts![]()
No issue with mine at all.
Have you tried different sticks in the same slot?
Or tried any of the other slots?
Tried upping the voltage?
So do my 2 x Gigabyte X58 mobos but Flex Mode still takes away some overall performance from the system as it has to make allowances for the 2 different channel typesThe Asus boards (and most X58 boards in general) run in 'Flex Mode' with 4 RAM slots filled. A hybrid triple channel mode - First 3 slots run in triple channel mode, 4th slot runs in a single channel type mode. Works perfectly on my rig with 4 x 4Gb Corsair Vengeance.![]()
Yeah I have 2 8 GiB sticks and 2 2 GiB sticks. Only because I can't use the 2 GiB sticks elsewhere...all my other PCs have low-end motherboards with 2 RAM slots!The Asus boards (and most X58 boards in general) run in 'Flex Mode' with 4 RAM slots filled. A hybrid triple channel mode - First 3 slots run in triple channel mode, 4th slot runs in a single channel type mode. Works perfectly on my rig with 4 x 4Gb Corsair Vengeance.![]()
but do before vs after 3 vs 4 ram sticks its usually slightly faster overall with just 3 sticks!!
Any synthetic benchmarks the usual suspects like 3D mark etc etc. I did this a few years ago found 3 sticks are overall a few % faster score wise which I put down to the system has to make internal allowances for the flex mode.I've never bothered before, just ran my first three sticks in triple channel and the last in single - in flex mode overall. However, you've got me curious now. What would be an accurate way to test overall system performance in 1)Flex Mode with all 4 slots populated and 2)Triple channel only mode with just 12Gb?
Been looking into this, but Gigabyte doesn't list the Xeon5650 or anything like that, as compatible with ANY of their X58 motherboards. I've got the X58A UD3R
http://uk.gigabyte.com/support-down...8D5BBA0B7340&s=Intel Socket 1366&cs=Intel X58
I see 55xx Xeon's on there but they are listed as incompatible with my REV 1 X58A UD3R
I see that Xeon W3690 is compatible with my MoBo. It's also 6 core/12T, and is apparently a good overclocker, but very hard to find no eBay and around £140.
Whats the diff between the W3690 and and the 5650 (other than the 2nd hand pricing).
Don't worry, I have the same motherboard and I run an X5675 in it. Just make sure you update the BIOS to the latest and you'll be good to go.
I've just ordered one from eBay. guess I need to get me some paste now.
Shoulda waited for recommendations I suppose. I went ahead and ordered some Arctic Silver 5, which looks ok too.Thermal Grizzly Kryonaut!!![]()
