BT Infinity & FTTx Discussion
This works, but it's not really a long term solution for a network with > 10 devices on.
It's how I've always done it. All my Windows machines and my Android phone have custom DNS set. Would be easier to do it on the router but alas mine doesn't support that. I like static IPs anyway so it's not much extra trouble.
Yep. I'm using a USG along with a Draytek 130 VDSL modem and a couple of Unifi AC-LR's.
There's a big thread on Ubiquiti stuff so it might be worth having a read through that.
Thanks - will do.
I saw someone else recommending the Draytek; I take it that it beats the pants off the white modem BT used to dish out?
Also, whats the USG software/feature set like now? I like the look of it, but upon reading it was pretty poor out of the box.
yeah - Ubiquiti AP handles all the wireless stuff. I switched from Sky to BT recently , the great thing about using the Ubiquiti AP was all the wirless stuff in the house didn't need changing passwords/networks etc as they are all still on the same AP, despite changing routers and providers etc. Saved loads of time.
Sounds good. How good are the APs? Is one plenty to handle a four bed house with thick walls? Or would I be sensible having one AP upstairs and one downstairs?
I personally don't think there's much difference.
Oh, well that would save me a decent amount of cash then.
is what I'm looking at, adding something like the draytek on top of that would add £100, and I've got a currently negotiated budget of £1,000 to spend on equipment, but that has to include cabling and wall ports.
I only went for one as I want to view stats. My cabinet is an ECI one and you have to hard modify the ECI modems to see stats, something I wasn't prepared to:
a) do it myself, or
b) pay an extortionate amount for one already done on eBay.
Apparently it's best to match the cabinet types and I'd heard that the Vigor 130 is good with the ECI cab and should support new features as they come out so I tried it out.
In reality I probably sync at the same speed if not a little slower than either the ECI or Huawei modems I've had before. I have wondered about trying another one to see what happens to my speed but I don't really want to spend money for the sake of it.
No idea if it will be an ECI or Huwaei cabinet.
The only one I can find nearby is
and that doesn't look like either. There must be a more recent cabinet elsewhere.
I just realised that it's been 5 years this month since I first got FTTC. In the last 5 years the maximum speed available via FTTC hasn't improved and yet prices have increased. AFAIK FTTP rollout in areas that already have FTTC is pretty non-existent.
Quite depressing really.
That's not an FTCC cabinet, it's just a regular cabinet to distribute copper that comes to it from the exchange.
So is the Vigor 2860 the recommended router for Infinity FTTC then? Currently have a Home Hub 5 but looking at alternatives.
I have been using a Draytek 2860n for almost three years with PlusNet VDSL2 (Openreach hardware), it's pretty solid connection and the modem supported G.INP with a firmware upgrade. I like the modems but they are quite expensive, there is also many features that most regular users would never require. Once setup they are troopers mind and never need attention. They are really an enterprise grade router/modem, if you work from home or need the features such as VPN or running your own servers then yes there definitely worth buying.
Part of any decent DHCP server options is to change the DNS addresses it hands to DHCP clients.
Sounds like the HH6 doesn't have it.
Nope, each PC sees the hub as the DNS server which in turn sees a fixed BT DNS server.
It appears all the websites I have issues with start with the same IP address as my internal devices (192.x.x.x) could this link to it somehow?
Good shout. Did that yesterday, this is then until now:
Beyond 6pm I can barely push 7mbit, but the upload stays fairly consistent at around 8-10mbit.
As soon as you see the quality settle on the graph straight up to 48-52mbit.
On TalkTalk up until switchover day I was getting 70mbit consistent no matter the time of day.
Yup. Switched over last Friday from TalkTalk 76mb to BT Infinity 1. Not sure what to do.
