They'd just remove the steering wheel. Who needs a wheel which has been the same since the first cars.
The magic button
Estimates suggest that this 'magic button' boost for qualifying – which changes the mapping of the engine – is worth around 80bhp.
We know from the Belgian Grand Prix that Mercedes customer Williams was left three-tenths of a second down when neither Felipe Massa nor Valtteri Bottas could use this qualifying setting on Saturday afternoon.
Even using the 980bhp figure, which includes the 160bhp that comes from energy recovery from the MGU-H and MGU-K, it means the internal combustion engine is producing around 820 bhp.
It's not just that they'd remove the wheel.. they'd remove it, and then in three years they'll introduce us to the Apple Steering Circle, which is really just a wheel but they'll claim they invented it.
Interesting article about the life of an F1 mechanic on the BBC.
Divorce, fire & 22 hour days... - BBC
I knew it was gruelling but I'd imagine you'd want to be really driven (no pun intended) to want to do it for what is a fairly modest salary, given the weekly working hours. It appears there aren't as many perks as you'd hope given the jet set life.
Am I the only one who is drawing a connection between the reversal of the radio ban in F1 and the improvement in form of Nico Rosberg? We saw similar as the coaching got more and more hands on before his form went from strength to strength. Then the ban got brought in and he slumped clearly. Then the ban was over turned again this year and his form is on the rise again. To me this is a perfect example of why the ban was a good thing, it went a little to far but could have been scaled back to appropriate levels.
I personally am not a fan of driver coaching and that is the element where the driver used to make the difference but the gap can be closed by such open radio and that's a shame.
Maybe I am just reading to much in to this.
Agree with you on this, much as I detest Rosberg, he's simply doing a better job than Lewis and therefore you can't really take that away from him.Good notice actually.
But I've now accepted fate and have conceded that Nico is going to win this WDC. Don't see Lewis matching him now
In a race, the Honda engine currently uses too much fuel relative to its rivals, who have applied highly advanced lean burn combustion solutions, which allows the limited fuel to produce maximum horsepower throughout the race.
With a conventional combustion set up, the Honda cannot match this from good engineering alone, so a step change is required in the combustion design. For Ferrari and Mercedes, this is a process known as pre-chamber ignition, whereby a small chamber is formed inside the cylinder head between the spark plug and the main combustion chamber. This gets filled with a rich fuel mixture. The main combustion chamber gets filled with only a very weak fuel air mix, which would be hard to ignite with a conventional spark plug. When the spark plug ignites the fuel in the pre-chamber, the resulting flame vents through small holes into the main combustion chamber, which then burns the weak fuel mix easily. This creates a long power stroke, despite the largely weak fuel mix.
Such technology requires a very different cylinder head architecture, along with special fuel injectors, spark plugs and – critically – special fuel, to be able to react to the unusual combustion process.
Honda have earmarked development tokens to be spent in Malaysia to allow a big upgrade to the engine. With the turbo, MGU and inlet system all now optimal, it’s expected that a lean burn technology will be the result of this development. This will ultimately bring Honda closer into line with its rivals, allowing them to push the engine for maximum power throughout the race, rather than having to curb its performance to manage the fuel available. This could be the key that unlocks the McLaren-Honda’s potential.
to be fair Ive heard Hamilton asking questions about settings on the wheel mid race that the engineer cant tell him now because of the rules...... (Im not picking LH out, Im sure it happens to others also)
The Spaniard will therefore use a new ICE (internal combustion engine), turbocharger, MGU-H and control electronics this weekend, which, while putting him at the back of the grid, should add to his stockpile - a move that will be outlawed next season - and get him to the end of the season.
It could be a completely moot point, but it does feel that some of the natural driver skill and feel is taken away when you can be told exactly where to gain time by braking later etc, which to my knowledge is now allowed again.
I've not seen anything about any rule changes in this area although the issue was raised after Lewis took his 7 billion place penalty and filled a warehouse with spare engines at Spa. Has anyone got any detail that they can link me to?
