Please tell me you're accessing it over a VPN.
No, I found when I got home that I hadn't enabled the remote access because I was going to set an extremely long password but hadn't got around to it.
Mine is accessible from the internet but on a port in the 5 digit range.
Fibre Max will appear on the website from Monday I believe. At the moment it's only available over the phone.
How are you measuring the download? Via a speed test or looking at the sync speeds in the sky hub maintenance page?
Where did you get the 75meg figure from?
Have you tried the master socket test port?
Are you connected to the router with a cable?
Speedtest is crap. My line syncs at 80Mbps but only get 25-30 from speedtest.net
What is the sync speed in your sky hub page?
I just use the dslchecker link result are:
Yes, ninjah. That's bad. You should double check this page
https://secure.sky.com/my-broadband
and see what it says is your download speed range. You're on about 25Mbps there.
