I thought I had to use a filter? The plug doesn't fit the socket otherwise
People say that restarting the router will eventually slow down the connection although having restarted my router at least 25 times in the last few days this does not seem to be the case.
The filter I have looks like this:
So I'm not sure that's an option? I'll have a look and see if I have any others.
I don't have a home phone anyway so at least that's not a problem
What do you sync at and what's your max attainable?
A good few years ago. Fibre Max now comes with a free Hub 3.0, did you request one or is one being sent automatically?
Each time you unplug it you are risking DLM cutting in and slowing your line down even more.
As long as you cleanly switch your modem/router off - so use the power button, this shouldn't happen.
Everything supports "last gasp" so the signal sent is a "I've switched off, please don't let DLM cut in".
