Mine goes into death sleep occasionally , can see notification light flashing but it wont wake up, have to cycle the power. Bit of a deal breaker having a phone that randomly stops working so you miss work calls.
Trying desperately not to bite on the Moto X while it's at £229 right now. If I could keep this going to January I'd be content at it giving me 3 odd years
Think mine does the same, though I've not had the notification light at the same time. It just wont do anything, have to hold down the power button and it restarts. Odd as it can happen when I was using it just seconds before absolutely fine.
Its been doing this for some time, probably should replace it but still holding out for something I really want.
£229 isn't bad for the Moto X. Especially with its decent battery and 4G (I think it has 4G). Just wish it had the same developer friendly side as the Nexus 4 as I'd go for it in a second.
Or you could wait and see what the One + 2 brings, it might even drop the price of the One + 1![]()
Mine has started doing this recently (did it a couple of hours ago in fact), really annoying as it's always been a great phone and I'm in no desperate hurry to upgrade it.
Mine seemed to get better when I moved to the Mirage kernel, so I'm guessing my black screen/hard power off issue is the battery on it's way out.
I r dissapointI've been holding onto my Nexus 4 eagerly awaiting for the Pixel phone, only to be massively disappointed by the pricing of it. My Nexus 4 is dying a slow death so need to make a decision on my next phone. From reading around it looks like the best options are
Nexus 5x (before stock sells out)
One Plus 3
HTC M10
Any recommendations? I'm leaning towards either the Nexus 5x or OP3, just can't choose between them.
