I can officially say I'm giving up on my stock wheelset..
I need a -;
disc wheelset
strong/reliable
6 bolt disc fitment
up to £300
anything worth looking at it?
That was a bit on the ball gargling side. The rain wasn't such s problem, it was the wind.
I need a -;
disc wheelset
strong/reliable
6 bolt disc fitment
up to £300
What you lot talking about the weather for? Lovely and dry down here, just a bit windy.
Ordered the rest of the di2 now! Hopefully get a chance to set it up at the weekend!
Derp. Cold & clear dry day here today.
Turbo tonight for me, with my 'sore bits' I'm probably going to skip commuting tomorrow as well (at least until the bruising has gone down on my hip, my mobility is around 75/80% today).
Also going to see if rolling my 810 back to version 5.00 fixes it's 'issues', as it'll also wipe/factory reset it (one of the other things I've been meaning to do with it).
Ross, I can't find much info on the 520's screen, but see lots of people with them broken (far more than any other model, could be a design flaw?). Looking at 'teardowns'/repairs of other models they all appear to be made a very similar way. Easy to repair, if able to source the correct screen...![]()
Didn't turbo last night, but rolled my 810 back (very easy!)Turbo tonight for me, with my 'sore bits' I'm probably going to skip commuting tomorrow as well (at least until the bruising has gone down on my hip, my mobility is around 75/80% today).
Will turbo tonight for it's first test...!Wow! That was easy. Downloaded the update file from http://www.gawisp.com/perry/agree.html, renamed it GUPDATE.GCD and copied it to the Garmin folder on the device. Got a message about the version being older than what was already installed when I turned it on, told it to go ahead and overwrite it and IT WORKED! It also erased all user settings but that's not a big deal.
Good find, out of stock once you choose any combination but you should be able to find the splines elsewhere.https://www.mantel.com/uk/dt-swiss-r24-spline-disc-road-wheelset
Not sure if they come with Centrelock to a 6 bolt adapter.
Good deal & great looking wheels on your cannondale, they are quite 'loud' though, are the decals stickers and can be removed?I've been running fulcrum racing 5 DB for just under a year now and I'm very happy with them! They aren't the lightest wheel but it was a great saving over my stock wheels, they were much stronger and more aero too! I got them in an introductory sale for £229.99!
Ah, I thought you'd quoted €60 for the repair and £50 for the screen, so around £100 for the total. At €60 I'd say it was well worth it, if you consider a screen €30, tools €10 and time €20 it's a good price!Looks easy enough to do, but I may as well just get them to do it for me/ get a new one. For 60euros it's really not worth the 5/10 euros I'd save!
You also have your hoods on the front wheel![]()
Wicked! I found out yesterday you can connect Di2 to your garmin. I'm not really sure why (you get gear ratio, which gear, charge level etc. which could be useful as my junction box is hidden) but it's a gadget, so I now want to do it. Not spent time working out how to do it yet, might do it at work today!
The oils & lubes generally are biodegradable (although to note my 'cheapy' Virosol citrus degreaser /floor cleaner I buy does discolour grass), the things they are cleaning off (mostly road grime) probably are not...!Serious cleaning. Where are you meant to do it?
Last time round I did it on the lawn and made a hell of a mess! - most of the oils and lubes are biodegradable right
I have all the product just not really sure on the location...
Rubbish! Hope it clears up for you! I've struggled to keep off the bike for the last couple of days, not even 5 days since I came off yet!been off the bike for nearly 3 weeks with a niggling injury in my thigh and a holiday. Was hoping a rest would clear up the thigh issue but alas no......off for a visit to the sports physio tonight to see if it's anything serious or not.
Welcome back. I would probably choose dhb over altura!
I've thought about doing weights over the winter (just the compound lifts like deads, squat, bench and o/h press) but the cost of gym memberships in London is extortionate so I guess I'll just stick to intervals on the turbo!
yup, my gf can dead 100kg xD
