Loving it so far, making so many mistakes though due to how much there is to learn again. Got pummeled by Brazil in one game, wasn't overly worried with his 5 warrior force but then realised that cities can't ranged attack units anymore unless you have walls built
Only came across two bugs at the moment. That tech boost that requires you have a 6 pop city works even if you use that city to build a settler (which is -1 pop). If you build a settler at 4 pop then raise the city to 5 pop you get the boost.
The other more annoying bug for me is the cam pan doesn't work properly using the mouse to drag, having to use the arrow keys :/
