https://www.strava.com/activities/750872514
Happy with that for a first go. Like their event format!![]()
Only 58.6 mph? Tsk.
Good luck for this morning mate & enjoy!I wasn't going up them full gas (though was still working) because I had a solo slog home and when it came down to it wanted to enjoy the slopes than focus on a segment timeI'll give it some beans when I come back
If the weather permits tomorrow morning and my legs are still functioning I'll light a match up to the first view point on the lighthouse ride
SRAM PC1130. Amazing chains for the money (usually £14ish but out of stock atm on Woggle).11 speed chain of any type (cheap as possible, for CX/turbo bike)
Thanks for Zwift clarification.Day off tomorrow which I predict will mainly be used for swearing at mudguards. If I get them on quick I'll do a 50 miler taking in a disused railway, if not I'll ride a quick(ish) 20 on it.
23mm internal rim is nice and wide!Probably use the Vectors occasionally when I know I can do some cross routes without the need to walk!
https://www.strava.com/activities/750702719
Great first result, well done!Anyway, I did the Cat D, which to be fair was fairly easy. I kept having to hold back up climbs to keep my average power to my category. I wasn't really too sure of what the rules were... either way, was decent and came in 3rd, which is nice.
http://www.zwiftpower.com/v2/race.php?id=1311 (page 2)
Quite interesting looking at your power/speed/cadence on the climb, your power level (220W) looks quite low for you, were you holding back? How much of that is the trainer and how much of that is zwift's impact? Your HR isn't that high so showing some good pacing if that's what it was? Love the 58.8mph burst over the top!![]()
New tyres (Michelin Pro4 End V2 25mm) feel so plush I had to keep looking down to see if I had a puncture! Not sure how much grip there is from these on damp roads when cornering but certainly there's going to be more than my previous (factory fit) efforts. Suppose in an ideal world we'll have tyres that wriggle/twitch a little before they actually full on let go - so you get a bit of a warning. I know I ask too much.
Anyway, if I don't get a ruck of PB's on the way home they're going in the bin.![]()
It is currently running Schwalbe CX something or others in 35mm. Using my usual source for these thing I think I'll run just over 45 PSI in the front and a smidge under 60 in the rear, if the tyres are rated to go that low that is.Thanks for Zwift clarification.
Good to hear the Mustang arrived and was quick to setup! What tyres has it come with? 25/28mm? I've found pressures make a HUGE difference to feeling on my 28mm, dropping from 90psi to 85psi on the front makes an incredible amount of difference. I even dropped down to 80psi on the front (as my commute road has lots of broken tarmac on it) and know I could go much lower. I think 85psi in the back is perfect and I usually keep my front only slightly lower.
Does anyone have any idea where the cheapest place to get 11 speed chains/cassettes are?
Part | Wheelies | Tredz | Rose | Wigg | PX | CRC |
105 5800 12-25 cassette | £40 | £40 | £31 | £32 | £34 | £32 |
Ultegra 6800 11-28 cassette | £50 | £50 | £44 | £47 | £40 | £47 |
Ultegra/DA 11 speed chain | £25 | £25 | £23 | £25 | £34 | £28 |
SRAM 1130 11 speed chain | £14 | £14 | £ | £14 | £13 | £20 |
They're better for wet road grip than many others! Very supple tyres (high TPI) so give you lots of feedback without wearing too much. I did switch my 25mm out last time for Conti 4Seasons after a couple of wiggles over wet drain covers and getting a slice in one. I'm back on them now in 28mm and probably won't switch them out unless the weather really deteriorates (wet/snow/etc). I have the Roubaix Pro my Diverge came with I'll switch back to and will probably use them instead of Conti 4Seasons as they're 1/3 cheaper with loads of tread. No idea how much they wear though...!New tyres (Michelin Pro4 End V2 25mm) feel so plush I had to keep looking down to see if I had a puncture! Not sure how much grip there is from these on damp roads when cornering
Faceplant crew signing in.I'd take losing a couple of mph in a corner to face planting the road any day of the week!
Quite a bit lower than me, I tend to run slightly high as all of my riding is on roads and quite fast (not saying you're slow!) so don't want to sacrifice too much speed.It is currently running Schwalbe CX something or others in 35mm. Using my usual source for these thing I think I'll run just over 45 PSI in the front and a smidge under 60 in the rear, if the tyres are rated to go that low that is.
My road bike is on 28's and I run that at 70 front, 85 rear.
'Quicker' isn't much use if you're puncturing every other week... I've found much lower than 80 on my 25mm's really felt like any pothole could end in tears. 28mm are going to feel like it even more so...I watched the GCN video on pressures and they said it was quicker on 28s running lower pressures. Really dropped them right now. I might try it on mine, as I'm on standard fat boy 90/95
EDIT: Merino base layer suggestions guys, long/short sleeve doesn't matter, ideally don't want to spend over £20 so I can buy ~5. I'm feeling the cold loads recently and temperatures have not even been below 5 degrees this week. Will be wearing them under work clothes with possible cycling commuting use during sub zero winter weather.
I put 100psi in my new tyres (25mm) for general road riding - is that a bit much, or about right? You 28mm guys run lower pressures than 25mm then?
anyone tried the crud roadracers k3?
getting a pair today, will see! my bike has no mounts, no holes nothing in the forks![]()
Bike discount now competitive for you guys? I find it's impossible to touch their prices anywhere else most the time.
Had my race tonight. Mate of mine did Cat A, which makes me cry thinking about 4-5w/kg.
Code:Part | Wheelies | Tredz | Rose | Wigg | PX | CRC | 105 5800 12-25 cassette | £40 | £40 | £31 | £32 | £34 | £32 | Ultegra 6800 11-28 cassette | £50 | £50 | £44 | £47 | £40 | £47 | Ultegra/DA 11 speed chain | £25 | £25 | £23 | £25 | £34 | £28 | SRAM 1130 11 speed chain | £14 | £14 | £ | £14 | £13 | £20 |
Only thing to note would be bundles & delivery costs & time. CRC have some pretty attractive cassette and chain bundles. The delivery time & cost from Rose don't make much sense (not saving enough).
2 orders - Wiggle (105 cassette & 5800 chain, if the 1130 was in stock) and Ultegra cassette & 1130 from PX. If you needed other kit you could get the 105 cassette/bundle from CRC, nothing else from there makes sense from that list unless bumping an order up for a bigger total for the 10% off...
100psi for 25mm is generally what vast majority of people will run. It's too high for me and very harsh as I am bit of a twig so I run 90 front and 95 rear.
I have a set of the MK3's in the post and they should get here today I think. Will let you know how I get on but will be a while as the winter bike aint even been out yet![]()
Thinking my problems is looking on cycling websites lolEDIT: Merino base layer suggestions guys, long/short sleeve doesn't matter, ideally don't want to spend over £20 so I can buy ~5. I'm feeling the cold loads recently and temperatures have not even been below 5 degrees this week. Will be wearing them under work clothes with possible cycling commuting use during sub zero winter weather.
Bigger tyre = more air volume = lower pressure required for tyres for the same feel as higher pressure smaller volume tyres.I put 100psi in my new tyres (25mm) for general road riding - is that a bit much, or about right? You 28mm guys run lower pressures than 25mm then?
Much of it depends on road conditions, if I was only fast A/B road riding with good surfaces I'd be running higher... But 50% of my riding is commuting where speed isn't too much of an issue, but comfort is. The remainder 50% leisure riding probably 20% is along back roads with bad conditions/surfaces/crap on roads so I again need the comfort and grip of lower pressure.100psi for 25mm is generally what vast majority of people will run. It's too high for me and very harsh as I am bit of a twig so I run 90 front and 95 rear.
Hahahahaha, good luck!anyone tried the crud roadracers k3?
Shouldn't need to return a cassette/chain!That's quite useful, thanks. Certainly cheaper than I'd found, even with CRC BC discount
I don't order from Tredz though. They have cack service.
Aw rubbish, what happened? Fingers crossed it all sorts out!
