Pretty accurate budget RMS multimeter
How do you know?
That's still fairly tragic :(
I never got how Americans managed to get so little from so much!
However, new set of headers on there, a new carb, up the exhaust bore...now we're talking!
It's because it'll rum on anything from pirate grog to melted butter for about 3 million miles without a service.
We're used to engines being a bit more finely tuned, where as Americans like engines to be as sophisticated as banging a pan with a spanner. ;)
thats a heck of a lot of kit there, storage and cost wise.
business or personal use?
i miss my DS1010+, it was a fantastic bit of kit.
Not sure how competitive OcUK are on the drives but at 310 quid a pop, that's 2.4K not including the NAS itself. :eek: :D
edit: scratch that, they are PRO drives which cost even more. :p
Yes, sort of.
If you use Synology Hybrid Raid then it can expand as you add more disks to it, so you can start with 4 disks and then add 4 more later or whatever.
Not sure you can use Raid 6 with SHR though, mine is Raid 5 equivalent, so one disk redundancy not 2.
Edit - definitely think about rebuild times for failed disks as well, a raid group is more vulnerable when it's got a failed drive, replacing it stresses the other drives, and the drives are getting bigger but not faster. Rebuild times of a failed 1TB drive are significantly lower than those of an 8TB drive.
I hope in the future that SSD gets bigger and bigger, because 8TB SSD would rebuild very fast indeed.
Yes, sort of.
Yeah... it's not Raid6
Raid 6 for 8x8TB drives = storage volume of 6x8TB = 48TB usable
