OK running from the dragon, still stuttering, wether I look around or not it makes no change![]()
It's locked at 60, no SLI support, no native ultra wide and juddering like mad!
Bethesda never fail.![]()
Very, very underwhelming compared to a fully modded with ENB. None of the character models have been updated and the colours look washed out when you're used to running realvision.
If things change once the modders get hold of it, time will tell.
Great community, it's what keeps Bethesda in business!OK the above post definitely solved my stuttering.
Either:
Turn off Gsnyc
Limit it to 60hz
Verify files.
Nice and smooth now!
I'll wait for a 3440x1440p patch, shouldn't be too long![]()
Do saves sync over between versions? I want to play vanilla on my ultrabook and enhanced on my desktop.
This is new???
bUseTAA=1
isnt TAA Nvidias newer AA implementation or am i thinking of something else?
