I drove into work today, fearing the weather. I averaged about 11mph. This is compared to averaging close to 16mph on the bike. Lame.
man up
I try this, but I have one set on 28s, one 25s with 60mm presta, one 40mm presta, then 27.5 mtb and 29er... I have a boat ton of tubes!
Rule #5 & #9!I drove into work today, fearing the weather. I averaged about 11mph. This is compared to averaging close to 16mph on the bike. Lame.
I tend to always buy 25-28 tubes now as I won't run 23 tyres again (If I swap a tube for someone on 23's that's their problem for not carrying their own tubes lol). You could just buy 25-28 tubes with 60mm valves to cover every road eventuality and run long valves on your normal rims. And of course MTB you should be running tubeless!I try this, but I have one set on 28s, one 25s with 60mm presta, one 40mm presta, then 27.5 mtb and 29er... I have a boat ton of tubes!
Just make sure you retain the Halfords packaging and have no soul!Order from Wiggle.
Purchase from Halfords for extortionate amount.
Return Wiggle tubes to Halfords.
Good work mate, it's surprising how much being clipped in can make a difference. I recently sold an old bike with flat pedals, I took it once around the block before doing so and found it a very strange sensation (after riding clipless for ~4 years & only riding flat pedals 3 time during that time!).
See you on Zwift sometime!?![]()
You mean you don't have a spare stock of 10 tubes at home? Tut tut.
Yup, it works with trainers listed on the website!I thought the whole Zwift thing was more geared towards smart turbos? I've got the Fluid 2 so just set it up and rattle away with the effort scales on the CTHX Cycles youtube trainer sessions.
EDIT
Just gone onto the Zwift website and it does support the Cyclops Fluid 2 and I have a speed and Cadence sensors so it could work for me.
Fingers crossed then as I've already ordered!Mountain Warehouse stuff is generally of poor quality from my experience. Never liked any of their hiking gear though I have not tried the merino.
Rule #5 & #9!
Just make sure you retain the Halfords packaging and have no soul!![]()
What a noob. I'm actually really disappointed in you as I expected better.I had 3 spares which were 650's some howThe tube that's been out with me most of the year as a spare in my pocket has been the wrong size tube this entire time haha.
Not bad considering most of them are open until 8pm weeknights, 6pm saturdays and 5pm sundays! Very handy for emergency need-it-now maintenance parts!As I type this I'm pretty certain they price match Wiggle?... least local stores have for me and others around the country.
Lulwut?!They also price match themselves as they charge more in-store than online for so many items![]()
Basically trainers listed have a known power curve (inbuilt resistance level at given speeds) so it can calculate zpower for you (Zwifts virtual power). Using this it calculates how your onscreen avatar moves, as your trainer isn't 'smart' then Zwift cannot alter the resistance for you, it can only slow you down on screen (as your power output doesn't increase, increase the output and you'll speed up!). It's not strictly 'smart' but still interactive enough to enjoy, you just have to control your resistance levels, rather than the trainer being controlled by software.![]()
That should do it!
