The comments above in this thread about how amazing heated seats are.
Also, you don't drive everyday do you? So I guess your requirements are different to most people.
If I wanted it, I'd have had it.
[TW]Fox;30226826 said:Not really true though is it, buying a used car is a compromise - we often have to go without things we'd want to get a car in the right condition or at the right price. I certainly have every time I've bought a car, so the idea that you made a conscious decision to pick a car with zero fitted equipment is just nonsense, nobody does that, it was just what happened to be the spec of the car that came up.
I have driven with the roof down in colder conditions than what we've been having this week, and not once have I thought "damn, wish this thing actually had heated seats". It just does not matter to me one bit to be an issue.
And like I said, if it did, then I'd just buy the elements off 2nd hand seats, the switch panel from BMW and fit it myself in an afternoon.
[TW]Fox;30226876 said:Exactly the same arguments I used to use against heated seats when I didn't have them. Now I do, I'd not be without them and most of what I said was probably just me trying to convince myself.
https://forums.overclockers.co.uk/showpost.php?p=8731122&postcount=64
etc
