I think someone posted that germans IRL wanted the shotgun banned because it was too lethal and inhumane
Yup, whereas Gas and the Flamethrower were so much more humane
A fully manned bomber is invincible to all but AA emplacements. It can gib planes that try to shoot them down, and no one can coordinate multiple fighters to hit that.
DX12 is still a bit of a mess. Gone back to DX11.
I'm still baffled at the Assault class. It literally is starter smg then 10 shot guns and then the HellRiegel. Why oh why is there nothing in between?
Why sooo many different shotguns! Those should mostly be different smg or something abit more offensive.
The shotguns maybe 3 tops.
There is 3 shotguns. The Model 10, Trench and 12G auto.
Server problems right now?
I honestly think shotguns should be removed from fps games like this. The trouble with them is the balancing. They have to be one hit kill at close range, but how do you balance this against making smgs useful only at shorter ranges without giving them so much range that they impede on assault rifles. All shotties ever seem to do is annoy people. Yes we can balance them and severely limit the range or everyone can change to them to counter but in the end they are still easy mode weapons that are just frustrating to play against. It's not a war simulator so we don't have to have shotties.
Also, when using Steam voicechat, the in game volume drops significantly and I can't figure out how to fix it. Anyone got any ideas?
Then we should remove sniper rifles as they have too much range. Then remove scopes on assault rifles. Then remove the automatico which is ridiculous at close range. Where do you stop with it? We'd end up with everyone using the same gun. I don't really mind the shotguns, they only seem to be half an issue on Argonne forest, and they are pretty easy to avoid if you play smart and avoid the narrow passages.
I remember while back I had this happen but it wasn't steam chat.
Right click speaker and open playback now select the option furthest to the right and select do nothing.
Sorry not at pc atm for correct name etc
...and this is why I play Division. What a mess from DICE. You'd think they'd have learned from BF4 but NOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!
