Thought this was a decent bargain if it turns out to be as good as the reviews indicate
https://www.amazon.co.uk/gp/product/B00BCCNZA2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
The mains security light down the side of the house kept tripping the electrics every time it turned on (not great when its a holiday let!!) so its been disconnected. Can't a) be bothered, or b) find time when there aren't guests in, to get the wiring fixed so this will have to do. Should be fine for hosing bikes down and sorting the recycling
Also have a bit of a leak internally. A "bit" is actually an understatement.
Moved in Janaury and the plasterboard under the beam was looking a bit ragged. It was gradually getting blacker and bits falling off so hacked a load off a month or 2 back to see if we could spot where it was coming down. Underside of the beam was a tad wet...
But after drying it off we never had any more dripping down. Until last week when we had about 36 hours of torrential rain and a strong constant wind. Seems to be the wind that really sets it off. Water was pouring down, starting in the middle of the beam, spreading all the way along it and also spreading back along the ceiling to the patio doors, where water was running down the door
Bit of a solution to gather as much water at a time as possible as the drips into the buckets were splashing so badly the floor was going to get ruined, was no way I could keep changing towels fast enough to keep it dry. So this worked but meant the main bucket needed changing every few hours
The problem is there is no concrete evidence where the water is coming in. We have a balcony which extends above the "back" half of the lounge (from the beam to the patio doors). The balcony is pretty badly tiled and gets a lot of standing water but that doesn't seem to be the issue as we've had tons of rain (Wales
) but it hasn't come in until the wind blows into the house for an extended period. So could be finding a route through around the upstairs patio door? But i tried to imitate the rain we had with the hose and not a drop came through. So I think it's going to be a balcony up and ceiling off job to find and fix it
