Haggled the service down from £560 to £400 with BMW after I told them I'd like to supply my own parts.
That £400 is inclusive of their parts. Bit miffed I had to haggle with a car dealership for something as routine as servicing, figured you're past that once you buy the car but evidently not.
Good result all the same.![]()
"Major service" makes it sound like they actually do a lot. The only BMW I can think of where a major service really is a major service is an Insp II on an E46 M3/Z4M (I'm sure other M cars need extra stuff done)
It's laughable that they can say that a spark plug change and an air filter change is "major". Now I'm sure they also beep the horn several times and check the state of your windscreen washer fluid, but to try and charge £410 on top of their regular service to change some spark plugs and an air filter is daylight robbery.
6 spark plugs are ~£90 from BMW (or £50 from Amazon if you buy the exact identical Bosch plugs - but that's a different thing). An air filter is £25.
Which means there is an extra £115 in parts and maybe £50 in labour at dealer prices bringing the total extra to £165 which is a far cry from the £410 extra they have attempted to charge. I guess they just take advantage of the people who think that "major service" means they rebuild the engine or something.
