- 18 Mar 2012
- Eastbourne
If I was you I'd drill a hole out of the rear near where the cables come down, and then another behind the PC then run the cables behind the desk and mount the power strip behind the desk too.
That way you'd only have cables visible for a couple of inches coming down from above before they go back.
+1
Snowballs on the other hand
So I picked up an Ikea Signum to put under my desk to help a bit with cable management.
http://www.ikea.com/gb/en/products/...unking-horizontal-silver-colour-art-30200253/
And behind my desk I picked up a Phillips Lightstrip+
https://www.amazon.co.uk/Philips-Pe...qid=1480633440&sr=8-1&keywords=hue+lightstrip
My next move will probably be to mount a power strip right hand side of desk, near the top but underneath, should be able to make it a bit "cleaner" on the right side where I have basically dumped all of the cables behind the PC
It was a cheap desk so I don't mind about drilling into it tbh! I made some holes at the back to feed cables in as well.
I can control it with my hue bridge, so I can change colour, brightness etc with my phone app, dimmer switch.
True, nothing like a good snowball between friends...
Nice features, not sure it would be worth £60 for me, especially as I would then also need a hue bridge as well![]()
Yeah not a bad idea, for the time being I've mounted it on the side near the top with a couple of screws.
I may revisit this at some stage but much happier with this than I was before!
Fidelio X1, hi 5.![]()
What are you hanging them on?![]()
Hi 5 with the SIGNUM
Old pics
Raspberry Pi zero
It's running my Pi-hole to free up the RPi3.
Interesting, are you running USB ethernet for Pi Zero?
Or would I do something like set router DNS to Pi Zero over a wireless dongle so I don't have to manually set each device dns?
Is this a slimmed down OS or could I just get an RPi 3 running raspbian as a tvheadend server as well?
So many questions!
Impressive. So do you camp out in winter in a hammock???
