The AMD Driver Thread
Will wait for some more feedback on the new drivers before trying them out but...
Matt:
1. 21.9 VSR support?
2. any adaptive vsync or fast sync like features, which nvidia have?
Recording worked very good for me in CS:GO no problems! (R9 380)
The only problem i notice is some flckering ? from time to time in CS:GO..
its in the known issues but under freesync? I dont have freesync!
I'm loving ReLive. I've been having a nightmare time trying to optimise OBS for Guild Wars 2 recording. However, using ReLive at 50Mbps, 1080p and 60fps, it's great! Any idea if higher bitrate will be available at any point? 1080 looks good, but I wouldn't be happy with the 1440 quality, especially after YouTube has butchered it.
The quality and settings will depend on GPU for example my 290 the hardware only supports 1080p @60fps newer GPUs will allow higher
I have a Fury and a 6700k, it seems odd that would restrict me to 50Mbps. Anyone with better specs that can confirm a higher bitrate option?
Ok just a heads up guys.
I was suffering with all sorts of issues earlier, had 3 black screens and complete system lock ups within 30 minutes of installing these, both on Desktop and in game. Shanks advised disabling MSI AB, since then not one black screen, so for me it looks like Afterburner or Rivatuner does not play nice with this new driver.
AMDMatt, can't you go back to the big wigs and explain how awesome having a full phat custom OSD available is? ;) include this in a driver and AMD are on to a winner here ;)
Also, is there anyway to record the last 30 seconds or minute whatever of gameplay like Shadowplay does?
Enable instant reply mate then set how long you want :D
What does this "HDMI link assurance" setting do? The "more" info. doesn't really explain it any better...
HDMI pffffffffffffffft
it informs you if you have a faulty or bad HDMI cable. I believe the reason it was included was because Raja had a faulty one when they were testing, or something along those lines. Would have been nice if they did the same for DisplayPort
gotta say though, I'm very impressed with this driver and all the goodies included in it. Well played AMD, very well played :)
No need for me to use display port yet... :D
Ah ok, shall leave it on for now then.
Yeah it is an impressive update. Personally I don't care for the recording stuff, however, it is nice to have the option especially the record last x seconds/minutes of footage should anything epic happen.
Seems like MSI afterburner is a bit broke now
Can't change the power limit at all?
Also, the core clock + memory clock have never shown 0 like that for me...
