- 19 Feb 2007
- Northampton
tact. link ultimate combined with 100% striker bonus
Ahhh ok, Yeah my primary DPS is hovering around 440K but that's not with tact link enabled or 100% strikers
Yeah like I said it was just an epeen post![]()
This d3 build is ****ing hilarious, switched to the assault shield and lol, that is all. Can't wait to get better gear and performance mods for it
Edit
any performance mods for shield being sold?
Sadly that MP5 ST is barely dropping for me,so im using Aug with destr,brutal,responsive,still have 235k dps and its ok'ish,even used this setup in CS run,i remember Gamble laughing how i was going togheter with CS boss and we literally having a duel,but he barely does any damage to me while i quite doing to him,besides guys were able to shoot him from behind 9no pun intended),so he didnt cover himself with shield
But yeah, only reason I am not using my spec. backpack is cause I don't have any other d3 gear, watch now as what I want will not drop at all
Already had 4 strikers drop today when using AB and now this... Yet when running strikers, about 3 strikers drop in a month...
Barretts+Spec Backpack+D3 should be quite the setup....![]()
I love my D3 setup,but you need high electr to have really good shield,so you should look for Spec backpack,shield mods very often drop in LZ boss'es,shouldnt be a problem.
Ideally you would want MP5 ST,on which you can mount 12x scope for 18% HS![]()
Was brilliant looking lol!!!How do you pull out shield?
I just loved the boss on CS going toe to toe with youWas brilliant looking lol!!!
:rofl:
Loving this game so far, just hit lvl 18
one thing though, i thought the max lvl was 30? i saw a guy earlier in a safe house who was 256!
The 256 is Gearscore, not Level. Currently 256 is the maximum Gearscore.
When you hit Level 30 (the maximum level) you unlock World Tiers and Gearscore.
The level of Gearscore items that drop is relative to the World Tier you are in. World Tiers (from 1 - easiest to 5 - Hardest) unlock as your Gearscore improves. So for example, Gearscore 256 items won't drop in anything but World Tier 5, although you can and will get lower Gearscore items than the maximum available in your World Tier. Once you have reached a certain level of Gearscore, you will get a message stating that your next highest World Tier is unlocked. It is then time to go up and start grinding for the higher level Gearscore items.
The Gearscore you see for players is the average across two primary weapons, sidearm and six gear pieces.
Generally, the higher the Gearscore, the better an item is (it hasn't always been this way).
Note that the content available at the different world tiers is identical...just the difficulty level of the content will change (so enemies in World Tier 5 are Level 34 for example).
In summary, the maximum level you can be is 30, the maximum world tier you can play in is 5 and the maximum Gearscore you can have is 256.
Cheers,
