Caporegime
- 18 Oct 2002
is this the only 38 curved SW monitor out?
Yup, looks like they have exclusivity for a while as they make the panels. It's awesome man, get one
Shame AMD don't have a top end GPU to actually drive this to the max. It's very tempting, but by the time VEGA comes out this will probably be cheaper and/or other alternatives available.
lol wont run on my 2012 Mac mini! Will stick to my Sammy 34er
Resolution issue? Output?
it does the full 3440x1440, the LG 38 is higher which the puney Mac mini HD4000 cant do apparently
Yeah, lucky is does the 3440 I suppose! It's getting on a bit now for integrated gfx![]()
I switched from an X34 dude (I'm going to post a thread tomorrow about it) and I couldn't be happier! This is superior in almost every way (size/panel quality/sound etc), and I have gaming nearly at the level that the X34 provided (with a single 1080).
OK thanks... that's interesting actually, as I have an X34 myself. Be good to see your full review/feedback. Did you do any side by side comparison shots?
Had one of these for a few weeks now. Sometimes colours look a bit faded, anyone else got the same issue? Seems to happen more on pictures etc.
Nope my colours look great, have you adjusted any settings, I'm using the same as tft central review
I don't think LG has ever made a G-Sync monitor? They haven't jumped in the locked tech but just support the open tech. The ball is on nvidias side to start supporting VESA adaptive sync. It's a simple driver fix - they just need to pull their finger out.
I see it the other way: I am using an AMD graphics right now and if nvidia would release a GPU with Freesync I would have bought it already. Waiting for nvidia...
I noticed TFTcentral mentioned a higher refresh rate version of the panel is in the works according to LG's roadmap but not coming until Q42017.
How is everyone finding the monitor ? am very tempted between this and the Samsung CF791
