Just had an email to say its been despatched. Sorry if this has been asked before but does fitting the EK waterblock void the warranty on the card?
if you RMA it with the EK block still attached I would say so.. otherwise not
I was using a 1080 for 2 weeks on my PG348Q while my txp system was down.Believe me there is a very noticeable difference.10/15fps is a lot at that res when trying to get the best of gsync@100Hz.Well in some games the perf increase is only 10FPS over a 1080 which at least to me wouldn't be worth the massive outlay.
I'll watch more vids and read more reviews first before deciding anything.
I take it Math isn't your strong suit?
Looks that way...
2 potatoes + 3 cabbages = 1 carrot
They are not wasted even at 1080p.
.Mostly used the TXP playing FarCry Primal since getting it a month ago. Today after a few hours gaming and 1hour+ up North in the snow I had two occurrences of artefacting, big squares/triangles appearing....hoping it's not the sign of a GPU hardware problem.[/QUOTE
Are you using the crap air cooler that Nvidia sell it with if so that will give you heat problems.
The stock cooler wont cause any heat problems, if temps get to a certain threshold it will clock back , its called thermal management, not to be confused with throttling when something is overheating.
Agree. It does have the stock cooler which I'm more than happy with TBH - not interested in overclocking GPU's or water cooling although might try it someday.
Only had the one occurrence so far so might not be anything anyway, or driver or game related. Have played the same game for 2+ hours since and all been okay. Am enjoying gaming more than ever with this card.
After all the talk of vega, and what it can and cant do I am real pleased I got the titan now. at first I was thinking it could be short lived, but now Vega isn't going to surface until june ish. the 1080ti looks like its a maybe, if vega beats the 1080. The titan XP is going to serve me well.
I felt that way at first with this being my first Titan.I looked at others and taught you're mad.I eventually joined the club and now when I fire it up all those negative taughts just disappear
Waste of money and you do nothing but fund the NVIDIA greed machine, how could you??!
Just saying it now so nobody else has to
Great card, I'm jealous.
 I believe I will now skip a gen with this card.Well that's what I hope.
I believe I will now skip a gen with this card.Well that's what I hope.After all the talk of vega, and what it can and cant do I am real pleased I got the titan now. at first I was thinking it could be short lived, but now Vega isn't going to surface until june ish. the 1080ti looks like its a maybe, if vega beats the 1080. The titan XP is going to serve me well.
I felt that way at first with this being my first Titan.I looked at others and taught you're mad.I eventually joined the club and now when I fire it up all those negative taughts just disappearI believe I will now skip a gen with this card.Well that's what I hope.
That's what I'm doing. My two Maxwell Titan-X's still play any games I've got at max settings. The only real kick in the teeth is when the new cards come out and yours loses 50% of its value. But if you do skip a generation I think they're not "that" bad value wise.
