Have taken a punt on this little number with a couple of spare bottles and a v2 spares kit.
Fancied trying a squonker on a budget but the Frankenskull's just look too flimsy. Will report back once it's arrived (shipped today).
couldnt get on with the limitless rdta plus.
I'm a big fan of the Merlin. It's a very underrated tank. Super easy to build on and great flavour. I use mine with no restrictor and it gives a good - slightly restricted - direct lung vape.
I would recommend it to anyone.
i got myself a Reuleux 2/3, im very underwhelmed by it, just doesnt seem powerful, wondering if there is anything i can do to check, before i request a exchange maybe.
take it you're using 3 decent batteries?
guess it depends on your definition of powerful but i've not seen any hint of lacking up to 150w.
there's a firmware update to take it up to 250w now i beleive.
Lol how powerful do you want it be?? I had one but exchanged it for a dna200 mod but the 2/3 I never found underpowered. Like adolf said earlier, use some decent batteries.
But really how powerful do you want it to be?? My mod does up to 200 watts and I vape between 50-90 watts depending on what tank I use. I go up to 90watts on aspire cleito120 tank and that rated to 120 watts at least.
What's your setup tank wise?? Trust me at 90watts it's plenty powerful and mod is similar to the 2/3 mod.
What wattage are you vaping at?
That was possibly the most poor way to explain what i mean, the device its self is powerful, but under temp control it just doesn't work as it should, using a Crown with Ni200 coils .15, ramp up set to 45w for .3 seconds, 510F. just vapes very weak no flavor no warmth.
The exact same settings on the Alien, Fuchai, 213 and the Cuboid produced excellent results.
ahh, fair enough, i dont do tc myself so that might have something to do with it.
hows the cold ohm reading on it compared to the others? could possibly be the issue if it's not reading that right, either that or it's using settings for the wrong material.
At what point should I be getting in touch with FT about lost parcels? Next week will mark 2 months since I ordered a 25mm serpent mini, it spent a month going back and forth between various places in china and was sent to the UK on the 10th of dec, no updates since. I know its been caught in the xmas flood of mail, but I'd be expecting to see it by next week surely?
Happy 2017 everyone!
It is the start of a new year. Let’s kick off 2017 with a discount code, fancy 30% off your order?
Apply the discount code 2017 to receive 30% off your order.
www.T-Juice.com
Make sure that T Juice is part of your New Year’s resolution.
Be a bestie and pass this onto a friend and help them switch from nasty tobacco to Vaping.
* This Promotion Code will be valid from now until 23.59 GMT on the 3rd of January – discount code is limited to 3 bottles of concentrate and 10 bottles of premixed.
Join the club mate. Mine's said the same thing on the tracking page since the 2nd December. Asked them to look into it w/ China Post but said it can take up to 2 months for a reply. Just submit a ticket and ask them to do the same.
EDIT: Forgot to say, my order using UK Express Post took 6 days from dispatch.
Anyone know if theres a way to find clones of popular ejuice that only uses FA concentrates as i want to buy the fa supersix but clones of Pound IT need stuff from various flavor companies which sucks especially when they say in them they need FW concentrates.
