Cheers mate for the advice, I'll have a look into what you just mentioned. But I'll also wait to see if anyone else has any advice before deciding on what to do.
10% jackfruit tpa
8% blackberry tpa
1% sour tpa
It's a clone of seduce juice blackjack that I've been enjoying for the past few months and anyone I've given samples of it to has also loved it too.
Anybody that likes a fresh flavourful fruity juice should love this, can be a shake and vape but after a couple of days it's really shines
Going to start this myself...only thing lost on a little is the Nicotine...what am I looking for there?Nicotine
PG
VG
Bottles
Syringes
Gloves
Clean area
I would reccomend one shots to start with, most of the time they will have a reccomended mix ratio, lots of apps and websites to help with the recipe. Its honestly a lot easier than you first think
I've probably got about 200/300ml of juice made up at the moment, ive spent less than £30 on everything to make that and have enough left over to make another 500ml.
If you're getting into mixing, PLEASE get a set of scales and do it by weight.
Whats the benefits of doing it by weight?
I have decent scales already.
Darkstar vapour, best place in my opinion! 100ml of 7.2%/72mg nicotine with delivery for £9.49. My advice if you plan to keep making your own juice after TPD drops is stock up! get a litre or two and split it into smaller glass bottles and pop it in the freezer to extend the life. After a few little sums earlier its going to get almost twice as expensive having to buy the little 10ml nicotine shots![]()
I am having some trouble here... I NEED a matching drip-tip for my Pandora Mod... I've contacted the usual suspects (Vince, Big, Dibley) and no-one has anything...
Do you guys have any idea where I can get one? It HAS to fit flush on my Rose3...
Might not be what you're after as its a stubby tip...Wotofo have a range of tips that have a similar design...
https://www.fasttech.com/products/0/10025595/5561403-authentic-wotofo-wide-bore-510-drip-tip
Hit the drop down at the side to see the other variations. I have a 5 and a 7 (orange and blue), find them very comfortable
E: FT is the only place I've found that sells them.
Nicotine
PG
VG
Bottles
Syringes
Gloves
Clean area
I've unfortunattely got back into the habit of smoking and the only way i managed to ut it out before was vaping so I'm back in this thread.
Things have moved on a lot so I could use some advice. I'm more of a MTL guy but am open to the possibility of switching to DTL so was thinking of covering all bases and seeing what I prefer and I also wanted to try squonking so with that in mind I was considering getting the following:
Smok G-priv 220 ( for use with 2 tanks one MTL one DTL)
Aspire Nautilus X for MTL
A Frankenskull clone for Sqounking with either a Hobo Drifter or SXK Hadaly
A sub ohm tank maybe the Smok TFV8
Any suggestions?
Also am I going to need anything else (other than batteries, juice, wick and coils)?
