Permabanned
- 5 Apr 2006
How does the memory frequency rating work? I mean it runs at an actual 1.25Ghz but is advertised as 10Ghz.
Wikipedia said:Taking a GDDR5 with 5 Gbit/s data rate per pin as an example, the [Command Clock] runs with 1.25 GHz and both [Write Clocks] at 2.5 GHz... GDDR5X targets a transfer rate of 10 to 14 Gbit/s per pin, twice that of GDDR5...
Essentially, it [GDDR5X] provides the memory controller the option to use either a double data rate mode that has a prefetch of 8n, or a quad data rate mode that has a prefetch of 16n. GDDR5 only has a double data rate mode that has an 8n prefetch.
Finally I can join the club
Boosted to 2025 out the box, and currently running +100/+450 with great results. Very happy with it.
I have the same card. It's a beast!
Welcome to the club![]()
Have you checked if it has those thermal pads installed, those "temporary fix" on the card?
Does that involve removing the cooler?
You should be able to see from the side profile, when you're facing the FTW logo
I think it has the pads, but I can't be sure.
Also, i think you copied my build
Yep, it has them
